Understanding your Wyze Indoor Cam Pan Status Light
You'll find the status light on the front of your Wyze Indoor Cam Pan. No light? Make sure it's properly connected to power.
⚡️ All Wyze devices have a handy status light that helps determine what state the device is in.
Wyze Indoor Cam Pan Status Light Guide
Before Setup:
  • Solid red - The camera is powered on and initializing, recording an event, or you are watching the live stream.
  • Flashing red - The camera is ready to connect.
  • Flashing red and blue light - Connection is in progress.
  • Flashing blue light - The camera is connected and finishing setup, or updating its firmware.
  • Solid blue light - The camera is powered and fully connected.
After Setup:
  • Solid red - The live stream is being viewed or a recording is in progress.
  • Quickly flashing red - Siren is in use.
  • Solid blue light - The camera is powered and no operations are running.
