About Wyze Air Purifier
A luxury air purifier, without the luxury price.
Our favorite Wyze Air Purifier features:
  • Whisper Quiet: Wyze Air Purifier operates between 21 and 53 decibels, which is 4db quieter than a kitten's purr. Sleep beside it on low and speak next to it on high.
  • Air Quality Indications: The handiest app interface we've ever designed with real-time data about the air you breathe.
  • Allergen Alerts: Custom alerts about the air outside, including updates about pollutants.
  • Laser Particle Detection: In Auto Mode, the high-precision laser continuously measure air quality and adjusts cleaning power automatically.
  • Smart App Control: Take control of your air with the Wyze app. Track your Air Quality Index history, get reminders to replace your filter, and set up automations. The purifier even works with Alexa and Google Assistant so you can control it with your voice.
  • Three Filter Options: True HEPA grade Allergen, Wildfire, and Formaldehyde filters offer 99.97% efficiency across a wide range of pollutants.
  • Powerful Cleaning: There's enough power to clean a 500 ft² room over three times every hour with a rating of 350m3/h CADR (206 CFM).
