Sharing your Wyze Air Purifier
The Sharing feature lets other people access and use your Wyze Air Purifier. Have a family member or other close friend who wants fresher, healthier air? Share it with them in the Wyze app.
Important: Only share your Wyze devices with people you know and trust.
To share your Wyze Air Purifier:
  1. In the Wyze app, tap on your Wyze Air Purifier.
  2. Tap on the Settings icon to open your Device Settings.
  3. Tap Share, then Share with a new user.
  4. Enter the email address of the person you want to share your air purifier with.
    • Or, select someone from your Recent Shares list.
  5. Tap Share.
What can a shared user do?
Shared users will be able to:
  • Turn the air purifier on/off
  • Enable/disable Auto Mode
  • Enable/disable Sleep Mode
  • Unlock/lock the device (Kid Lock)
  • Adjust Fan Speed level
  • Set the Timer
  • Turn on and off Notifications
    • Filter life is running low
    • Urgent air conditions
  • Filter Management
  • Name the filter
    • Set the Filter Type
    • Set Location
  • Enable Return to Clean Air
  • Create Automations
  • Remove the device from their Wyze app.
Shared users will not be able to:
  • Share a device shared with them.
  • Rename a device shared with them.
Keep in mind:
  • There is no limit to the number of users you can share your Wyze devices with.
  • There is no limit to he number of Wyze devices you can share.
  • The sharing feature is set per device. To share multiple devices, you'll have to invite users to each manually.
