How do I turn off the alarm?
If someone makes 5 consecutive failed attempts to unlock the lock, the alarm will sound for several minutes unless turned off.
To turn off Wyze Lock Bolt's alarm:
Access Code Attempts: Unlock the door with your fingerprint, or connect to the lock using the Wyze app to silence the alarm and unlock your door.
Fingerprint Attempts: Unlock the door with your access code, or connect to the lock using the Wyze app to silence the alarm and unlock your door.
Can I just unlock the door with the latch?
No, for safety reasons, manually turning the knob will not silence the alarm. It will turn off on its own within 5 minutes.
