Wyze Lock Bolt is rated ANSI/BHMA Grade 3 and has a UL10c 20-minute fire test rating.
- Is my door compatible with Wyze Lock Bolt?
- Can two people control Wyze Lock Bolt at the same time?
- What is the ANSI and Fire Test rating for Wyze Lock Bolt?
- Can I install Wyze Lock Bolt horizontally?
- What is the max recommended door thickness for Wyze Lock Bolt?
- Can I use Wyze Lock Bolt with a multipoint locking system?
- Is the indoor side of Wyze Lock Bolt weatherproof?
- Can I set up multiple Wyze Lock Bolts on my Wyze account?
- What are the dimensions of Wyze Lock Bolt?
- What certifications does the Wyze Lock Bolt have?
- See more
