- Wyze encrypts your lock’s information and cannot access your codes or fingerprint data.
- All your codes, schedules, and fingerprint data are stored locally in the lock.
- Since Wyze Lock Bolt is Bluetooth-only, there is no cloud connection which significantly decreases security risk.
- With Anti-Peep Technology, you don’t have to worry about faded numbers or if someone watches you enter your code. You can add extra numbers before and after your code and Wyze Lock Bolt will still unlock.
- Is my door compatible with Wyze Lock Bolt?
- Can two people control Wyze Lock Bolt at the same time?
- What is the ANSI and Fire Test rating for Wyze Lock Bolt?
- Can I install Wyze Lock Bolt horizontally?
- What is the max recommended door thickness for Wyze Lock Bolt?
- Can I use Wyze Lock Bolt with a multipoint locking system?
- Is the indoor side of Wyze Lock Bolt weatherproof?
- Can I set up multiple Wyze Lock Bolts on my Wyze account?
- What are the dimensions of Wyze Lock Bolt?
- What certifications does the Wyze Lock Bolt have?
- See more
