Wyze Garage Door Controller Setup Guide
Installing and setting up your Wyze Garage Door Controller should take about 10-20 minutes, and is as simple as setting up the camera, making a few connections, and placing the QR code on your garage door.
Before setting up a Wyze Garage Door Controller, use our Compatibility Checker to make sure your existing garage door opener is supported.
To set up your Wyze Garage Door Controller:
  2. On the Add menu, tap Device.
  3. Tap Cameras > Wyze Garage Door Controller.
  4. Check the box to confirm that your opener is compatible. Tap Next.
  5. Review the Safety Information thoroughly. Tap Next.
  6. Go to your garage door opener. Then tap Check Wi-Fi Signal Strength.
  7. After checking your signal strength, tap Continue Setup.
  8. Select whether you're setting up the garage door controller with or without a Wyze Cam v3*.
  9. Follow along in the app, and with the video below for installation.
Additional Note
* We recommend you use a Wyze Cam v3 with the upgraded round-shaped USB cable that comes with the Garage Door Controller Bundle. If you use your own Wyze Cam v3 with a flat-shaped USB cable, be sure to mount the camera further away from the garage opener antenna to avoid signal interference.
