Wyze Garage Door Controller and Google Assistant
Wyze devices can be paired with and controlled by voice assistants including Google Assistant. Once set up, you can use your voice to command Alexa to control your Wyze Garage Door Controller.
Before setting up Google Assistant with your device:
  1. Download the Google Home app (iOS/Android).
  2. Open the Google Home app.
  3. Tap the + plus icon.
  4. Tap Set up device.
  5. Tap Works with Google.
  6. Search for "Wyze Home" in the list and sign in to your Wyze account.
To add your Wyze Garage Door Controller to your Google Home:
The Google Home app automatically links with devices on your Wyze account. Your Wyze Cam should already be added!
  1. In the Google Home app, scroll and check the devices under Linked to you. Your device should be on that list.
  2. In the Wyze app, tap on your your garage door controller's Wyze Cam v3.
  3. Go to Settings > Accessories > Garage Door Controller > Third Party Integration > Google Assistant.
  4. Create your 4-digit voice PIN.
Voice commands for Google Assistant:
To open your garage door:
You: "Okay Google, open (garage controller name)"
Google: "Can I have your PIN?"
You: "XXXX" <--your voice PIN
Google: "Sure, opening (garage controller name)"
To close your garage door:
You: "Hey Google, close (garage controller name)"
Google: "Got it. Closing (garage controller name)"
To check your garage door status:
You: “Hey Google, is my (garage controller name) open/closed”
Google: “(garage controller name) is closed”
Frequently Asked Questions
  • What commands does Google Assistant have for Wyze Garage Door Controller?
    • You can open, close, and confirm your garage door's status (open or closed).
  • Can anyone tell Google Assistant to open my garage door?
    • No, you must confirm your voice PIN with Google Assistant before the garage door will open.
  • Can I see the camera view of the Wyze Garage Door Controller on my Google Home display or Chromecast?
    • No, because although the garage door controller has a camera attached, it is a garage door controller. It is not a camera that you view with Google Assistant, but a door that you open/close with Google Assistant. While you cannot stream the view of your garage door to a Google device, you can still check your camera view via the Wyze app.
  • After telling Google Assistant to close/open my door, it still tells me the same status. What gives?
    • Your garage door controller needs at least 15 seconds to update its status. This is because the camera uses multiple frames to determine if the door is open or closed. So if you check the status immediately after asking Google Assistant to open or close it, you may receive an inaccurate answer.
