Problem
You cannot view microSD card recordings, cannot record to the microSD card, or your Wyze Solar Cam cannot detect the microSD card.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that Wyze Solar Cam’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the camera, please move forward with updating it.
- Verify that the microSD card is compatible with the camera.
- Wyze Solar Cam is compatible with microSD cards up to 32 GB in FAT32 format, and microSD cards up to 256 GB in exFAT format.
- Verify that the microSD card is properly inserted into the device
- Remove the microSD card and then reinsert it into the camera.
- Properly reseal the silicone cover of the microSD card slot.
- Check that the selected playback time is correct.
- In the Wyze app, navigate to the camera’s live stream > SD Card.
- In the timeline, scroll left and right to the desired footage date/time.
- Ensure that the MicroSD Card settings are correct.
- Navigate to the camera's settings > MicroSD Card.
- Enable Record to MicroSD Card and select Record Events Only.
- Please note that Record Continuously requires Wyze Solar Cam to be plugged into a 5V/2A power adapter (not included).
- Format the microSD card.
- To format the microSD card through the Wyze app:
- Navigate to the MicroSD Card settings.
- Next to Camera MicroSD Card, tap Format > Format.
- To format the microSD card through a computer, refer to How to Format your MicroSD Card.
- Restart the camera.
- Navigate to the camera’s settings > Restart Camera > Restart.
- Factory reset Wyze Solar Cam.
- Remove any microSD card that is inserted into the camera.
- Press and hold the setup button for 10 seconds.
- Once the status light starts flashing red, set up the camera as new.
