Wyze Solar Cam Connectivity Troubleshooting
Problem
Your Wyze Solar Cam shows offline in the Wyze app, loads slowly, or disconnects frequently.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Solar Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Confirm whether the status light is on.
    1. If not, refer to My Wyze Solar Cam won’t turn on.
  4. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  5. Confirm that the Wi-Fi network that the camera is connected to is functioning normally.
    • Wyze Solar Cam is only compatible with 2.4 GHz Wi-Fi networks.
  6. Switch between using the Wi-Fi connection and cellular/mobile data to determine if there is an issue with the Wi-Fi.
  7. Force close and reopen the Wyze app.
  8. Ensure Wyze Solar Cam has good signal strength.
    1. You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
    2. If it has 2 bars or less, try moving the camera closer to the router.
  9. Adjust the live stream resolution to a lower resolution.
    • Higher resolution requires more bandwidth and is more likely to cause slower connectivity.
  10. Reboot the Wi-Fi router.
  11. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  12. Factory reset Wyze Solar Cam.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 10 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
