Problem
Your Wyze Solar Cam is not charging with the solar panel, even on sunny days.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that your Wyze Solar Cam’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the camera, please move forward with updating it.
- Try charging Wyze Solar Cam using the included USB-C power cable and a 5V2A power adapter (not included).
- If there is no status light or charging indicator light, refer to My Wyze Solar Cam won't turn on.
- Check and clean the solar panel.
- Clean the solar panel with a soft, damp cloth.
- Check the solar panel’s cable for any kinks or damage, such as cuts, corrosion, or moisture in connection points.
- Verify that the solar panel’s cable is inserted correctly and securely into the camera.
- Ensure the solar panel is mounted in a position where it is able to receive at least 1 hour of direct sunlight per day. Adjust the placement, orientation, and angle of the solar panel, if needed.
- For users in the northern hemisphere, we recommend placing the solar panel facing south, with a tilt angle of 30° for optimal performance.
- For users in the southern hemisphere, we recommend placing the solar panel facing north, with a tilt angle of 30° for optimal performance.
- Ensure the solar panel is free from obstacles such as overhangs or shade that could block direct sunlight.
- During a sunny midday, check if the app is registering the solar panel’s charge.
- Navigate to the camera’s live stream.
- Check the battery icon.
- If charging using the solar panel, there should be both a lightning bolt and a sun icon.
- Restart the camera.
- Navigate to the camera’s settings > Restart Camera > Restart.
- Factory reset Wyze Solar Cam.
- Remove any microSD card that is inserted into the camera.
- Press and hold the setup button for 10 seconds.
- Once the status light starts flashing red, set up the camera as new.
Note: When the temperature drops below 32°F (0°C), the solar panel will automatically pause charging to protect the battery.
