Yes, Wyze Bulb Cam Pan Color is outdoor-rated.
Wyze Bulb Cam Pan Color is IP65-rated and can be installed indoors and outdoors. However, most socket adapters are not waterproof and must be covered. Do not install the bulb cam where the socket connection might come into direct contact with water unless using a verified waterproof socket adapter.
