Wyze Bulb Cam Pan Color works in E26 sockets.
Wyze Bulb Cam Pan Color is compatible with E26 sockets, in open light fixtures. If the socket fits a standard bulb, like a Wyze Bulb, and the camera has a clear view from the bottom, then it is compatible.
👉 Wyze Bulb Cam Pan Color is not compatible with fully-enclosed light fixtures.
Exception: if the sconce itself is too large and long, more than 20 cm from the socket to the sconce edge, the sconce may obscure the camera's view.
