Wyze Bulb Cam Pan Color fits most sconces with an inner depth of less than 20 cm, from socket base to sconce edge. For larger sconces, we recommend using a Wyze Lamp Socket with a Wyze Cam v4.
- Can I set a schedule to turn off the light?
- Does Wyze Bulb Cam Pan Color have Privacy Mode?
- How is Wyze Bulb Cam Pan Color powered?
- Does Wyze Bulb Cam Pan Color work with Wyze Accessory Bulbs?
- Can I change the brightness of the bulb?
- I have a very large light fixture. Will Wyze Bulb Cam Pan Color fit?
- Can I pan and tilt Wyze Bulb Cam Pan Color from the Wyze app?
- Does Wyze Bulb Cam Pan Color support 5 GHz networks?
- Is Wyze Bulb Cam Pan Color compatible with my fixture?
- What are the dimensions of Wyze Bulb Cam Pan Color?
- See more
