Tap the bulb icon in the Wyze app.
Wyze Bulb Cam and Wyze Bulb Cam Pan Color's light can be controlled using automations, like schedules and sunset/sunrise settings, and using voice commands. The bulb cam's light can also be controlled manually, with just a tap in the app.
To turn on/off the bulb cam's light:
- In the Wyze app, tap on your Wyze Bulb Cam or Wyze Bulb Cam Pan Color.
- In the toolbar, tap the Bulb icon.
- When green, the bulb light is on.
