What are the dimensions of Wyze Bulb Cam Pan Color?
Just how big is Wyze Bulb Cam Pan Color, and will it fit in your sconce? It probably will, but here are the dimensions for Wyze Bulb Cam Pan Color.
Related articles: Wyze Bulb Cam Pan Color Tech Specs, Is Wyze Bulb Cam Pan Color compatible with my fixture?
Wyze Bulb Cam Pan Color Dimensions:
  • Telescopic Rod Extended: 2.76 in × 2.76 in × 9.84 in (70 mm x 70 mm x 250 mm)
  • Telescopic Rod Retracted: 2.36 in x 2.36 in x 11.02 in (60 mm x 60 mm x 280 mm)
Telescopic Rod Length:3 cm
Weight of Wyze Bulb Cam Pan Color: 1.25 lbs (565 g)
