How do I unlock Wyze Lever Lock?
There are 5 ways to unlock Wyze Lever Lock:
  1. Scan your fingerprint with the handle
  2. Enter the access code and tap the unlock icon on the touchscreen.
  3. Use the Wyze app.
  4. Command Alexa & Google Assistant to unlock the door.
    • You must enable this feature in the Alexa or Google Assistant app.
  5. Use the physical key.
