It's not recommended, but check the spacing.
We do not recommend installing this lock on a door with a deadbolt, or a double-bore door, as there often isn't enough space between the bores. To install Wyze Lever Lock on a door with a deadbolt, you must ensure that there is enough space between the lock and the deadbolt.
Shown in the graphic below: If installing above a deadbolt, there should be at least 2 inches between the center of each hole. If installing below a deadbolt, there must be at least 5-5/16 inches between each hole.
