Yes, in your Wyze Lever Lock settings.
Generate a single-use passcode for a cleaner, contractor, or delivery that expires automatically after it's used.
To create a One-Time Code:
- In the Wyze app, tap on your Wyze Lever Lock.
- Tap Settings, then One-Time Code.
- Tap Expires, and set when you want the code to expire. Tap Next.
- Tap Create One-Time Code.
Note the code that displays, and tap Copy Code to share it. To delete the code, tap Delete Code.
