Can I get a set of replacement keys for Wyze Lever Lock?
No, each Wyze Lever Lock has only one set of physical keys.
Your Wyze Lever Lock comes with a set of two (2) physical keys that are unique to that lock. There are no replacement keys available, and Wyze does not provide duplicates.
We suggest you make a few extra duplicates at your local hardware store if you'll be using the key option often.
