Wyze Window Bird Cam Setup Guide
Before you begin setup:
  3. Unpack your Wyze Window Bird Cam box, separating the camera, and indoor and outdoor mounting materials.
To set up your Wyze Window Bird Cam:
  2. On the Add menu, tap Device.
    • If Bluetooth is enabled, your camera may be found automatically. Tap Set Up to skip to pairing.
  3. Tap Cameras > Wired Cameras or Others > Wyze Window Bird Cam.
    • You must use the included 5V1A power adapter and cable.
  5. Once the status light begins flashing red, tap Next.
    • The status light is located on the front of the camera.
  6. Single-press the SETUP button. It will say “ready to connect”.
    • The camera may say “ready to connect” without pressing the SETUP button. If so, continue with setup.
  7. In the app, check the box next to I heard, “Ready to connect”.
  8. Tap Begin Setup.
  9. If BluetoothⓇ hasn’t already been enabled, you’ll be prompted to allow BluetoothⓇ access. Tap Next.
    • If BluetoothⓇ has already been enabled, it will skip to the next step.
  10. The app will automatically begin searching for and pairing with your camera.
    1. Have multiple Wyze Window Bird Cams? Select the correct camera by tapping the MAC address on the bottom of the camera.
  11. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  12. Your device will continue pairing. Tap Complete to review details about your camera's functionality and follow the in-app instructions to mount your Wyze Window Bird Cam.
    • The camera's status light will now turn off to reduce reflections on the glass.
  13. Name your Wyze Window Bird Cam  using the text field, or by choosing a suggestion.
  14. Tap Next when done.
  15. You may have a prompt for a free trial of Bird Watch, designed specifically for Wyze Window bird Cam.
  16. Set up some automations on the Things to Try* page, or tap Skip and Done.
  17. You’re all set. Enjoy your new Wyze Window Bird Cam!
