Loved by bird lovers.
Wyze Window Bird Cam is a wired, window-mounted bird camera bundled with a bird feeder, designed for people to watch, capture, and share birds up close from inside their home.
Wyze Window Bird Cam features we flew in for:
- Up-Close 1080p HD Bird View. Optimized for close-range viewing at the feeder with a near-focus range of 10–20 cm, plus a high-speed 30 fps frame rate to capture quick movement with less blur.
- Easy Window Mount. The camera mounts flush against the inside of the glass using a mounting sticker, while the roofed feeder mounts securely outside with four twist-lock suction cups.
- Squirrel-Resistant by Design. Window placement helps keep the feeder out of reach compared with traditional pole- or tree-mounted feeders.
- Built-In Seed Tray & Nectar Feeder. Includes a slide-in seed tray with molded drainage channels and a side-mounted nectar pod for hummingbirds.
- Free Bird Detection. Get bird arrival notifications with thumbnails, local microSD recording, and clip sharing without a subscription.
- Bird Watch Subscription Upgrade. Adds bird species identification, bird facts, visit logs, 60 days of cloud storage, full-length event recording, and monthly Bird Highlights recaps.
- Unlimited User Sharing. Share live view and bird sightings with family and friends.
- 24/7 Local Recording. Supports continuous or event-only recording with a microSD card up to 512 GB, sold separately
