You want to know what the different status lights mean on your Wyze Window Bird Cam.
Wyze Window Bird Cam Status Light Guide
Wyze Window Bird Cam Status Lights: During Installation
- Solid red – The device is powered on and initializing.
- Flashing red – The device is ready to connect.
- Flashing red and blue – Connection is in progress.
- Flashing blue – The device is connected and finishing setup.
- Solid blue – The device is working properly.
Wyze Window Bird Cam Status Lights: After Setup is Complete
- Solid red – The live stream is being viewed, or a recording is in progress.
- Solid blue – The device is working properly, and no operations are running.
Note: Once setup is complete, the status light is automatically turned off to reduce reflections on the glass. It can bet toggled back on in Advanced Settings > Status Light.
