Problem
Your Wyze Window Bird Cam’s status light is not lighting up, or the device is not powering on.
Troubleshooting
- Make sure that the camera is powered using the power cable and adapter that came with the camera.
- Ensure the power cable is inserted correctly and securely into the camera.
- Wyze Window Bird Cam uses a micro-USB to USB-A power cable.
- Wyze Window Bird Cam’s power port is on the back of the camera.
- Press and hold the setup button until you hear “ready to connect”.
- Try plugging the camera into a different power outlet.
- If possible, verify that the status light is not disabled.
- Navigate to the camera’s settings > Advanced Settings.
- Ensure Camera Status Lights is toggled on.
- If the camera still does not power on, try another power cable or adapter to determine if the cable or adapter is defective.
Notes:
- Wyze Window Bird Cam requires a 5V1A power adapter.
- The status light is located on the front of the camera, under the lens.
- The camera status light will be turned off by default after setup to reduce reflections on the glass. It can be turned back on in the Advanced Settings.
