Wyze Window Bird Cam Accessory Troubleshooting
Problem
You are having issues installing, using, or replacing one of the accessories (Perch, Fruit Fork, Suet Ball Feeder, Jelly Cup).
Troubleshooting
  1. Verify that the accessories are being installed on Wyze Window Bird Cam.
    • The accessories are not compatible with Wyze Bird Feeder or third-party devices.
  2. Identify the exact accessory and whether the specific issue is missing parts, incorrect orientation, poor thread fit, loosening, damage, or interference with the camera view.
  3. For seating issues, make sure the trays and accessories click fully into place — a half-seated tray can fall out of the feeder.
  4. To clean the accessories:
    1. Remove the accessory, wash with warm water and mild soap, and dry fully before refitting.
    2. Replace nectar/jelly every 2–3 days in warm weather using a 1:4 ratio of white sugar to water only – no dye or honey.
      • Note: Fermented nectar harms birds.
