My Wyze Window Bird Cam has poor image quality.
Problem
Your Wyze Window Bird Cam displays a distorted, blurred, or tinted image in the live stream or in recorded events.
Troubleshooting
  1. Check that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Window Bird Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Compare the camera’s live stream, a cloud event, and local microSD recording, if possible, to determine whether the issue affects all paths.
  4. Ensure there is nothing impairing the camera’s lens.
    • Remove any plastic film or cover from the lens.
    • Gently wipe the lens with a soft cloth to remove any dust or debris.
    • Check that both the inside and outside of the window are clean and transparent.
      • Note: We do not recommend mounting Wyze Window Bird Cam to a window that has a screen on it.
    • If there is a third-party cover on the device, please remove it.
  5. Verify that there are no additional light sources next to or pointing toward the camera lens that may cause interference.
    • If the camera is in the direct path of the sun, it is possible that a lens flare appears in the image. We recommend adjusting the position of the camera so that the view is not in the direct path of the sunlight, but this is an expected phenomenon in standard.
  6. Adjust the camera resolution.
    1. From the camera’s live stream, tap the resolution icon to toggle between the modes.
    2. Note: We recommend setting it to HD resolution.
  7. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  8. Power cycle Wyze Window Bird Cam.
    1. Unplug the camera from its power source for 5-10 seconds, then plug it back in.
  9. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera as new.
Note: Wyze Window Bird Cam does not have night vision or IR lights because the IR lights do not work through the glass, and there is minimal bird activity at night.
