About Wyze Mesh Router and Pro
Wi-Fi is finally easy.
Key Wyze Mesh Router features:
  • Industry-leading Wi-Fi 6. Easily stream 4K video, video conferences, and gaming at the same time with up to 1 Gbps internet speeds per router.
  • Eliminates dead spots and buffering. Each router covers up to 1,500 square feet and intelligently adapts to its place in your home.
  • Connect up to 50 devices to each router. Create a blanket of seamless Wi-Fi coverage by adding other Wyze Mesh Routers to connect your devices to.
  • Control with the Wyze app. Set parental controls, prioritize important devices, check the status of all your routers, all from the app.
  • Security by Firedome. Wyze Mesh Router's security is powered by an advanced security software to protect your devices from the world's most dangerous security threats.
  • Wired Ethernet backhaul. Each Wyze Mesh Router supports wired backhaul for faster speeds.
Key Wyze Mesh Router Pro features:
  • Industry-leading Wi-Fi 6E. Up to 5.4 Gbps Wi-Fi speeds, with 2.5 Gbps internet speeds across 75+ devices per router.
  • Eliminates dead spots and buffering. Each router covers up to 2,000 square feet and intelligently adapts to its place in your home.
  • Connect up to 75+ devices to each router. Create a blanket of seamless Wi-Fi coverage by adding other Wyze Mesh Routers to connect your devices to.
