What is Wyze Cam OG Stack Kit used for?
To stack Wyze Cam OG and Telephoto 3x together.
Our Wyze Cam OG Stack Kit allows you to stack your Wyze Cam OG and Wyze Cam OG Telephoto 3x on top of each other for a dual-camera system. That'll give you a wider field of view and a 3x fiex zoom lens, all clipped together. You can even stack two Wyze Cam OG or Wyze Cam OG Telephoto 3x devices together!
Can I stack other Wyze Cams to the OG cameras?
No, the Stack Kit is only compatible with Wyze Cam OG and Wyze Cam OG Telephoto 3x.
Can I stack other Wyze Cams together?
That'd be cool, but no. It is only compatible with Wyze Cam OG and Wyze Cam OG Telephoto ex.
