Wyze Cam Floodlight v2 Installation Guide
Installing your Wyze Cam Floodlight v2 is as simple as replacing your existing floodlight by connecting it to a junction box. As long as you have a junction box and neutral wiring, and self-installation is legal in your area, this process should take about 30 minutes.
-> You must have an existing junction box and a neutral wire to use Wyze Cam Floodlight v2.
-> At the electrical panel, shut off power to your junction box before proceeding.
Before you begin installation:
Check your local laws and building codes before doing any performing any electrical work. Your may live in an area that requires a permit and professional installation.
What’s in the box?
  • 1x Wyze Cam Floodlight v2 (Assembled)
  • 1x Mounting Accessory Kit
    • 6x Bracket Screws
      • 2x #6
      • 2x #8
      • 2x #10
    • 1x Ground Wire Screw
    • 1x Floodlight Screw
    • 1x Rubber Stopper
    • 1x Mounting Bracket
    • 2x Wire Nuts
    • 1x Hook
  • 1x Quick Start Guide
Required tools:
  • Phillips Screwdriver
  • Ladder
To install your Wyze Cam Floodlight v2:
  1. In the Wyze app, tap the +plus sign then Device > Cameras > Floodlight Camera> Wyze Cam Floodlight v2.
  2. Read the High Voltage warning before tapping Got it!
  3. Are you replacing an existing floodlight?
    1. If yes, tap I'm replacing an existing floodlight.
      1. At your electrical panel, turn off power to your floodlight. Tap Next.
      2. Carefully remove your existing floodlight. Tap Next.
    2. If no, tap I don't have a floodlight to replace.
      1. Do you have an existing junction box?
        • If yes, tap Next.
          • Check that your junction box is at least 10 feet off the ground. Tap Next.
        • If no, your wiring is not compatible with Wyze Cam Floodlight v2. Stop the installation process and contact a licensed electrician for assistance.
    3. Tap Check Your Wi-Fi Signal Strength in the Wyze app.
      • If your signal is Out of Range or Poor Connection, contact your ISP for options.
      • Tap Continue Setup.
    4. Tap Start Installation.
Continue below, following along in the Wyze app to wire your floodlight.
  1. Review the Installation page for what You Will Need for installation, and what's In the Box.
  2. Confirm that you have the required tools and items. Tap  Next.
  3. IMPORTANT: At your electrical panel, double-check that you've shut off power to your floodlight or junction box. Tap Next.
  4. Follow along in the Wyze app to wire your Wyze Cam Floodlight v2.
  5. Once installation is complete, turn on power at your breaker when prompted.
  6. Tap Begin Setup, then continue to Wyze Cam Floodlight v2 Setup Guide.
