Wyze Cam Floodlight v2 Setup Guide
Follow the steps in this article to set up your new Wyze Cam Floodlight v2. ⚡️
Before you begin setup, use our Wyze Cam Floodlight v2 Installation Guide to install the floodlight.
To set up your Wyze Cam Floodlight v2:
  1. After completing the installation process in the Wyze app, tap Begin Setup.
  2. The status light should begin flashing red.
    1. If the light is flashing red, check the box next to Light is flashing red, then tap Next.
    2. If the light does not turn on, press and hold the SETUP button on the side of the camera to reboot the camera.
  3. Wait for the voice prompt to say "ready to connect."
    1. After the prompt, check the box next to It said, "Ready to connect", then tap Next.
    2. If there is no voice prompt, press and hold the SETUP button for 10 seconds to reboot the camera, then try again.
  4. Give location permissions for the floodlight's Dusk to Dawn setting. Tap Next.
  5. Your floodlight will pair to the Wyze app - stay nearby.
  6. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  7. Your floodlight will connect to your Wi-Fi network.
    • If connection fails, wait for the voice prompt and try again.
  8. Name your Wyze Cam Floodlight v2 using the text field, or by choosing a suggestion. Tap Finish when done.
  9. You may have a prompt for a free trial of Cam Plus. Tap Continue.
  10. Set up some automations on the Things to Try* page, or tap Skip.
  11. You are all set! Your floodlight is set up and ready to go. Tap Done.
