How do I customize my modes for Cam Unlimited?
Cam Unlimited gives you self-monitoring modes that you can customize to fit your needs. Whether you're home, away, or want everything disarmed, here's how to configure it all.
What are the 3 modes?
The three modes are Disarm, Home, and Away. Alerts are driven by person detection only - not motion or other detection events.
ModePurposeSuggested Configuration
DisarmNo active monitoring. You will not receive any alerts.All cameras have detection notification settings turned off.
HomeActive monitoring for specific areas. You will only receive alerts from specified devices.All indoor cameras have notification settings turned off. Outdoor cameras send push notifications.
AwayFull monitoring for all areas. You will receive alerts from all specified devices.All cameras armed - push, critical alert, or alarms will be send depending on your setup.
Each mode is customizable.
For each mode, you can choose which devices are included and how each one responds when triggered.
ActionWhat it does
MuteSilences all notifications from the camera. Camera put in silent mode.
PushSends standard push notifications to your phone.
AlertSends a critical alert, which bypasses Do Not Disturb settings.
AlarmSends a critical alert and triggers the camera's local siren.*
*Note: Not all Wyze Cam models include built-in sirens.
To manage modes and notifications:
  1. In the Wyze app, tap on the Monitoring tab.
  2. In the upper-right corner, tap the dropdown arrow then tap Settings.
  3. Select the mode you want to edit (Home, Away, or Disarmed).
  4. Tap the assigned camera(s) to adjust the types of notifications you wish to receive for that mode.
    • Home and Away - You can toggle to Mute, Push, Critical, or Alarm.
    • Disarm - You can toggle to Mute or Push.
  5. Tap Save.
Modes FAQ
Can I set cameras to switch modes automatically?
Yes, you can set up schedules so that your monitoring modes switch at set times. For example, set a schedule to switch your mode to Away every weekday at 7:30 AM or to Home at 6:30 PM. You can also receive a push notification whenever the mode changes.
To set up a monitoring schedule:
On the Monitoring tab, tap the dropdown arrow, then tap Settings. Tap Monitoring Automation > Create Monitoring Schedule.
Can I see a history of when modes were switched?
Yes, Cam Unlimited keeps a log of whenever a mode was activated, the timestamp, and whether it was triggered manually or by a schedule.
To view your Monitoring Events:
On the Monitoring tab, tap the dropdown arrow. Next to Monitoring Events, tap View All.
Which devices are compatible with modes?
Most Wyze Cams and sensors can have custom modes. Not supported: Wyze Video Doorbell v1, Wyze Cam Outdoor v1 and v2.
Which security plans have modes?
Modes are available to all Cam Unlimited and Cam Unlimited Pro subscribers.
