Wyze Lock Bolt Access Code Setup
Once you've set up your Wyze Lock Bolt, it's time to add an access code! An access code is a PIN that you enter on the keypad to unlock the door.
Related article: Wyze Lock Bolt Installation Guide
Tip: An alternative to start this setup is to continue after setting up your Wyze Lock Bolt.
To set up an access code for Wyze Lock Bolt:
  1. Move next to your Wyze Lock Bolt with the Wyze app open.
  2. In the Wyze app, tap on your Wyze Lock Bolt.
  3. Go to Settings > Access Settings.
  4. Tap Add a new user.
  5. Tap Name to enter a name for the user, then tap Done.
  6. Tap Scheduled Access, and select Always or Recurring.
    1. If Always, tap Save.
    2. If Recurring, set the date range and when to repeat, then tap Save.
  7. Next to Access Code, tap Set.
    1. Enter a 4-8 digit code, then tap Next.
    2. Copy and Share the code if you want, or else tap Done.
  8. Tap the back arrow <. Your settings will be saved.
To reset a Wyze Lock Bolt access code:
Follow these same steps if you want to change or update an access code for a user.
  1. In the Wyze app, tap on your Wyze Lock Bolt.
  2. Go to Settings > Access Settings.
  3. Tap on the user you want to reset the code for.
  4. Tap Reset.
    1. You must enter a new 4-8 digit code, then tap Next.
    2. Copy and Share the code, then tap Done.
    3. Copy and Share the code if you want, or else tap Done.
  5. Tap the back arrow <. Your settings will be saved.
Additional Notes
  1. Access codes must be between 4-8 digits long.
  2. Access codes are encrypted and stored locally on your Wyze Lock Bolt.
  3. Each user can only have one (1) code.
  4. Wyze does not have access to your access code, Access History, or fingerprint data.
  5. Up to 20 access codes can be added per device.
  6. Up to 20 users can be added to a single Wyze Lock Bolt.
