Is 24/7 Local Recording going away?
Of course not - we love this feature!
A feature on every Wyze Cam with a microSD slot is 24/7 local recording, which gives you Continuous or Events Only recording with no subscription required. As long as you have a compatible camera with a microSD card installed, and recording is enabled in Advanced Settings, you're good to go.
Note that recording to a microSD card only records the footage, either a continuous recording or motion-based Events Only recordings. In order to locate specific events, you will need to manually review the footage.
Related: How do Cam Plus and a microSD card compare?
What does a security plan do differently?
With a security plan like Cam Plus, Cam Unlimited, or Cam Unlimited Pro, you get heaps of features beyond nonstop recording. You get features like 14-day cloud storage, Smart Detection, and the ability search your recordings with a text search (AI Video Search) rather than manually search through hours or days of footage.
