How do Cam Plus and a microSD card compare?
Considering adding a microSD card to your Wyze Cam, or signing up for Cam Plus instead? How about doing both? This article explains what you get with both options.
Wyze Cam + a MicroSD Card*
Using a microSD card with your Wyze Cam gives you the ability to record videos continuously, locally, and create Time Lapse videos. For basic, everyday use, a microSD card is the next level for your Wyze Cam.
Pick up a microSD card in our Wyze Shop.
Wyze Cam + Cam Plus
A subscription to Cam Plus gets you many more features. If your Wyze Cam has a Cam Plus license, you'll get motion-triggered (and unlimited-length) Event recordings, cloud storage, and smart AI features like Person, Package and Pet Detection. See the next section for the full list of what'll really bring your cam to the next-next level.
Subscribe to Cam Plus here.
Wyze Cam + Cam Plus + a MicroSD Card
What if you have Cam Plus and a microSD card? That means you get all the features.
  microSD card Cam Plus
Event Recording 24/7 Motion-Triggered
Storage Local Cloud
Storage Length Up to 4 Days with 32 GB 14 Days
2x and 4x Event Fast-Forwarding   √
Person Detection   √
Package Detection   √
Vehicle Detection   √
Pet Detection   √
Exclusive Subscriber Discounts   √
While a microSD card allows you to record continuously and locally, Cam Plus allows you to only record the events that matter - like when a person or pet is detected. While the microSD card is storing your recordings locally, Cam Plus comes with handy 14-day cloud storage that can be your backup if your cam is ever stolen. And as a bonus, Cam Plus gets you exclusive discounts at wyze.com.
Do I need both a microSD card and Cam Plus?
You might! It depends on how many Wyze Cams* you have, the type of cameras you have, and what you're keeping an eye on. If you're picking up a Wyze Cam to record Time Lapse videos of the sky, you're alright with just a microSD card. But if you're keeping an eye out for packages, want to get notifications when a person is detected, or are monitoring your home or property, Cam Plus is the way to go.
And if you're monitoring an area where you want a little extra security, like the garage or front yard, we recommend assigning Cam Plus or Cam Unlimited to your camera. That way you get continuous recording, as well as notifications about the things that matter most to you.
Additional Notes*
  • Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro do not support 24/7 Continuous Recording.
  • Wyze Battery Cam Pro, Wyze Video Doorbell, and Wyze Video Doorbell Pro do not support Local Recording.
