Automations help control your Wyze devices through Shortcuts, Schedules, and Device & Service Triggers. This reference article lists all of the triggers and actions available on Wyze Leak Sensor.
💡 A trigger is what happens to start an automation, like a command. An action is the result of that trigger, or the task you want your device to do.
Wyze Leak Sensor Triggers |
Wyze Leak Sensor Actions |
Detects a leak Has detected a leak for Becomes clear Has been clear for |
Turn on notifications Turnoff notifications
