Wyze Chime Automations
Automations help control your Wyze devices through Shortcuts, Schedules, and Device & Service Triggers. This reference article lists all of the triggers and actions available on Wyze Chime, which works with Wyze Video Doorbell v1.
💡 A trigger is what happens to start an automation, like a command. An action is the result of that trigger, or the task you want your device to do.
Wyze Chime Triggers
Wyze Chime Actions
Ring
Wyze Chime works with Wyze Video Doorbell v1. When the doorbell is pressed, the paired Wyze Chime will ring.
