Automations help control your Wyze devices through Shortcuts, Schedules, and Device & Service Triggers. This reference article lists all of the triggers and actions available on Wyze Garage Door Controller.
💡 A trigger is what happens to start an automation, like a command. An action is the result of that trigger, or the task you want your device to do.
Wyze Garage Door Controller Triggers |
Wyze Garage Door Controller Actions |
Close the garage door |
Wyze Garage Door Controller works with Wyze Cam v3 - triggers from the camera can close the garage door using the garage door controller.
Check Wyze Cam v3 Automations for the full list of automations for a Wyze Cam v3 paired with Wyze Garage Door Controller.
