Wyze Entry Sensor v2 Automations
Automations help control your Wyze devices through Shortcuts, Schedules, and Device & Service Triggers. This reference article lists all of the triggers and actions available on Wyze Entry Sensor v2.
💡 A trigger is what happens to start an automation, like a command. An action is the result of that trigger, or the task you want your device to do.
Wyze Entry Sensor v2 Triggers
Wyze Entry Sensor Actions
Opens
Closes
Has been open for
Has been closed for
Arm system*
Disarm system*
Alarm*
Turn on notifications
Turn off notifications
* Requires a subscription to Wyze Home Monitoring.
Wyze Entry Sensor v2 works with Wyze Home Monitoring, but most automations listed above do not require an active subscription. Sign up for Wyze Home Monitoring for automations that let you set up triggers to arm/disarm your system, and turn on the alarm.
