Pan, Tilt, and Zoom on Wyze Cam Pan
Wyze Cam Pan gives you added controls with Pan, Tilt, and Zoom. This gives you 360° horizontal coverage with a 93° vertical range, zoom capabilities up to 8x.
This feature is only available on Wyze Cam Pan. It is not available on Wyze Cam v1/v2/v3.
To control the Pan and Tilt:
  1. In the Wyze app, tap on your Wyze Cam Pan.
  2. Tap the directional control pad to move your camera.
    • You can also drag your finger along the Live Stream.
Note: Wyze Cam Pan has 360º coverage, but will not spin completely. The camera will stop and “You have reached the end" will display in the app.
To zoom in and out:
  2. On the Live Stream, double-tap or pinch to zoom.
Note: When you are zoomed in, pan and tilt the camera.
Motor Controls
Motor Controls lets you change how fast Wyze Cam Pan moves when you pan and tilt the camera.
To change your Motor Controls settings:
  2. Tap the Settings icon on the top right, then Advanced Settings > Motor Controls.
  3. Drag the slider to set the speed.
    1. By default, the rotation speed is 5. 1 is the slowest speed, while 9 is the fastest.
Note: Motor Speed does not affect the speed of Pan Scan or Motion Tracking .
