Wyze Cam Setup Guide
Follow along with the video or read the article below to set up your Wyze Cam v1/v2 and Wyze Cam Pan.
Before you begin setup:
  1. Download the Wyze app on your smartphone or tablet.
  2. Connect your device to a 2.4GHz WiFi network.
  3. Unpack your Wyze Cam Pan box, removing all plastic and packing materials.
  4. Plug the camera into power using the included USB cable and power adapter.
    • The camera’s status light will turn solid yellow when powered. When flashing, it’s ready for setup.
To set up your Wyze Cam or Wyze Cam Pan:
  1. In the Wyze app, tap Home, then tap + plus sign on the top left.
  2. Tap Add Device.
  3. Tap Cameras > Wyze Cam or Wyze Cam Pan.
    • When setting up a Wyze Cam Pan, the camera may rotate when plugged in.
  5. Pull the base from your camera and single-press SETUP on the bottom of the camera. It will say “Ready to connect”
  6. In the app, check the box next to “I heard, “Ready to connect”"
  7. Tap Next.
  8. Select your 2.4GHz WiFi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  9. Scan the QR code on the Wyze app.
    • Hold your camera up to your phone screen with the QR code displaying. It will say “QR code scanned please wait.” then “Setup completed.”
  10. In the app, check the box next to “I heard, “QR code scanned”"
  11. Tap Next. You’re set up, it’s time to name your device.
  12. Name your Wyze Cam using the text field, or by choosing a suggestion.
  13. Tap Finish when done.
  14. If you want to share your device, tap Share Device
    • If not, tap Maybe later.
Additional Notes:
  • Wyze devices only work on 2.4GHz WiFi networks. If you are connected to a 5GHz network, switch to a 2.4GHz network before setting up your device.
  • Having trouble scanning your QR code? A few tips to help:
    • Hold your camera 6-10 inches away from your phone screen.
    • Slowly move the on the screen away from the camera, then closer.
    • Tilt your phone screen slightly in case there's a glare.
    • Turn your phone upside down.
    • If you're on iOS, turn off "Invert Colors".
    • Make sure the QR code isn't distorted.
      • If you have an older device, the screen may be too small. Try a different device.
      • If your screen is cracked or scratched, the code may be distorted. Try a different device.
      • If you're using a beta version of the Wyze app, make sure the cursor is not on the QR code.
Still need help?
