Event Recording Schedules on Wyze Cam v1/v2 and Pan
Create an Event recording schedule so that your Wyze Cam only records videos during specific times. Don’t want Events recorded while you’re home in the evenings? Set your schedule to only record Events during the day.
Note: Without Cam Plus, Cam Protect, or Cam Plus Lite, your Wyze Cam will only generate a thumbnail image instead of an Event video.
To create an Event Recording schedule:
  1. In the Wyze app, tap on your Wyze Cam.
  2. Tap the Settings gear on the top right.
  3. Tap Event Recording > Schedule.
    1. Want detected Events to be recorded all the time?
      • Tap the toggle next to All Day to turn it On.
    2. Only want detected Events to be recorded sometimes, like when you’re not home?
      1. Tap the toggle next to All Day so that it’s Off and greyed out.
      2. Choose your Start time.
      3. Choose your End Time.
      4. Tap the back arrow < to save your changes.
  4. Tap which Events you want to trigger a recording.
    • Detects motion: An Event will be recorded when your camera detects motion.
    • Detects sound: An Event will be recorded when your camera detects sound.
  5. Your changes will be saved automatically.
Note: You must update your Event Recording Schedule for each Wyze Cam you’d like a schedule for.
Detects Sound and Motion
You can set your Wyze Cam to record a 12-second Event Video when it detects motion and/or sound. A subscription to Cam Plus, Cam Protect, or Cam Plus Lite is required for this feature.
To toggle your detection settings:
  3. Tap Event Recording.
Note: If you don’t toggle on either option, the camera will not record Event videos.
Cool Down Period
There is a 5-minute cool down or “rest” period after Sound or Motion triggers an Event video. Unless you have Cam Plus, which removes this cool down and gives you full length videos, there will be 5 minutes between every 12-second Event video.
Sound and Motion are separate triggers. If sound triggers an Event video, but during the 5-minute cool down the camera detects motion, another Event video will be recorded.
Related articles in this section:
Smart Sound Recognition
Smart Sound Recognition uses an advanced algorithm that recognizes the unique sound patterns of smoke alarms and CO monitors. With Smart Sound Recognitions turned on, alarms will generate a 12-second Event video and send a push notification to your phone so that you can act quickly.
To turn on Smart Sound Recognition:
  3. Tap Alarm Settings.
  4. Tap the toggle On next to the alarms you want to trigger an Event video.
    • Smoke alarm sound: An Event will be recorded when your camera detects a smoke alarm sound.
    • CO alarm sound: An Event will be recorded when your camera detects a CO alarm sound.
Note: This setting will work even if you have Detect Sound toggled to Off under your Event Recording settings.
