Sensor Videos
Wyze Sense lets you record a video with your Wyze Cam whenever a sensor is triggered. Any Sensor in your account can trigger any Wyze Cam on the same account.
To set up a sensor to trigger Sensor Videos:
  1. Open the Wyze app.
  2. Tap the sensor's listing on your Home tab to access the Device Screen.
  3. Tap the Settings icon in the top right.
  4. Tap Sensor Videos.
  5. Select as many Wyze Cams as you'd like to record a Sensor Video from the list.
  6. To finish, tap the arrow in the top left.
Any of the cameras that you have selected for that sensor will start recording if the sensor is triggered. Just like with Event Videos, any sensor videos will be stored in the cloud.
There are 2 ways to access Sensor Videos. The first is from the sensor's Device Screen, where you'll see a thumbnail of the video next to the event.
The second way is from the Events tab. These will show up as a Smart Video Alert.
