Grouping your Wyze Sense v1 Sensors
With grouping, you can control and organize multiple Wyze Sense devices in one place.
To group your Wyze Sense v1 contact sensors:
  2. On the Add menu, tap Device Group.
  3. Tap Contact Sensor Group.
  4. In the top field, Enter a group name, then tap Done on the keyboard.
  5. Select the contact sensors you want to include in the group.
  6. Tap Done on the top right.
To group your Wyze Sense v1 motion sensors:
  3. Tap Motion Sensor Group.
Editing the Group
You can edit a group from it's Group Settings.
To rename your group:
  1. Tap the group's listing on the Favorites or Devices tab.
  2. Tap the settings gear icon.
  3. Tap Name at the top.
  4. Enter a new name, then tap Done.
To reorder sensors in the group:
  3. Tap Motion/Contact Sensors in a Group.
  4. Tap and drag the three-lines icon to sort the sensors within the group.
To remove individual sensors:
  3. Tap the red icon on the sensor's listing.
  4. When prompted, select Yes.
  5. When finished, tap Save on the top left.
To delete the group:
  3. Tap Delete Motion/Contact Sensor Group.
  4. When prompted, tap Delete.
Note: Deleting a group does not delete the devices from your account, and only that group will be affected.
Additional Notes:
  • Groups for Wyze Sense v1 devices are limited to sensors of the same type; Motion sensors can only be grouped with other motion sensors, not contact sensors.
  • Grouped devices will not display individually on the Home screen, but within the group itself.
    • Exception: If that individual device is added to Favorites, it will display on the Favorites tab.
  • To view the sensors in a group, tap on the group's name on the Devices tab.
  • A sensor can only be added to one group at a time.
  • While a sensor is in a group, you can check an individual sensor's status (open/closed, all clear/motion) by tapping on that specific sensor in the group.
