Can I extend the length of cloud recordings?
Yes, with a subscription to Cam Plus!
If you would like to upgrade for longer videos on the cloud, check out Cam Plus. To learn more, visit our Cam Plus article.
Another option is using a microSD card with the ‘Record events only’ feature turned on will allow the camera to record the rest of the motion detection footage that the cloud video does not capture.
Note: A good way to use the Record events only feature is to view the Event video under the Events tab. If you believe there is more information needed you can then go to the Playback tab and view the rest of the footage.
Still need help?
