Can I use my Wyze Cam outdoors?
It depends on which Wyze Cam you have.
If you have a Wyze Cam v3 or a Wyze Cam Outdoor, then yes. They are both IP65-rated, weather-resistant, and were designed to be used indoors and outdoors.
But Wyze Cam v2 and Wyze Cam Pan have not been designed for outdoor use and will not be covered by our warranty if used outdoors. The lens, speaker, and charging ports are not weatherproof, and the camera should not be mounted or left outdoors for an extended period of time.
