Updating your Wyze Cam firmware version
When your Wyze Cam has a firmware update, you’ll be prompted to update in the Wyze app. But you can also check and update your firmware manually.
To check your firmware version, and update:
  1. In the Wyze app, tap on your Wyze Cam.
  2. Tap on the Settings gear, then Device Info > Firmware Version.
You can also check your firmware version from the Home tab by tapping Account > Firmware Update.
