No voice prompts when setting up Wyze Cam v3
Problem
You're setting up your Wyze Cam v3, but the voice prompts don't sound. There is no "Ready to connect" when you press the SETUP button.
Troubleshooting
If your Wyze Cam v3 doesn't play any voice prompts, check the LED status light (on the back). Note the color and see if it's solid, flashing, or not lit.
If your Wyze Cam v3 light is solid red:
  1. Confirm that you are using the power cord and wall plug included with your Wyze Cam v3.
  2. If you are, try using another power cord and wall plug.
    • If this resolves the issue, please reach out to support for a replacement power cable and wall plug.
  3. If the Wyze Cam is daisy chained to another Wyze Cam for power, try connecting it directly to the wall outlet.
If your Wyze Cam v3 light is flashing red:
  1. Try the setup process for your Wyze Cam v3 by following the steps in our Wyze Cam v3 Setup Guide. If at some point you are instructed to wait for a voice prompt, try to continue as if you heard the voice prompts.
    • You will know the setup is successful when the LED status light will change to flashing yellow-blue.
  2. If the setup is successful, please update the firmware to the latest version and test the speaker of the camera from the live feed.
If your Wyze Cam v3 light is not lit at all:
Check out this article for tips to troubleshoot: Troubleshooting your Wyze Cam v3's Status Light.
If your camera is still not finishing the setup process, reach out to our support team for help.
