Updating your Wyze Cam v3 firmware
To check your Wyze Cam v3 firmware version:
  1. In the Wyze app, tap on your Wyze Cam v3.
  2. Tap on the Settings gear, then Device Info > Firmware Version.
You can also check your firmware version from the Home tab by tapping Account > Firmware Update.
When your Wyze Cam v3 has a firmware update, you’ll be prompted to update in the Wyze app. But you can also check and update your firmware with the steps above if needed.
