What happens if the batteries die?
You'll receive a notification to replace them.
Wyze Lock will send you a Low Battery Alert to let you know when the batteries are running low. If you forget to replace the batteries, no worries–-there is backup power so you can still control the door. And because Wyze Lock doesn’t change the exterior of your deadbolt, your keys will always work.
