Travel Mode gives you the freedom to use your Wyze Cam Outdoor anywhere, even when you're away from home. This feature lets you use the camera without an internet connection, and it can be enabled on the camera or Base Station.
How It Works: When Travel Mode is enabled on a Wyze Cam Outdoor v1/v2, it allows the camera to emit a Wi-Fi network you can connect your mobile device/tablet to locally in order to view the live stream, set scheduled recordings, etc. It works the same way with Wyze Base Station. It allows the base station to emit a Wi-Fi network you can connect locally to view the cameras in Travel Mode connected to that Wyze Base Station. You can set a password on these local networks to increase security, but that is optional.
To Enable Travel Mode on Wyze Cam Outdoor:
Reminder: Wyze Cam Outdoor v1/v2 and Wyze Base Station must be set up and connected to the Wyze app before you can enable Travel Mode. Travel Mode must be enabled before leaving your home, as it cannot be set up remotely.
- In the Wyze app, tap on your Wyze Cam Outdoor.
- Tap the
gear icon in the top right. - Tap Travel Mode.
- Turn on the camera if it isn't already, then tap Continue in the app.
- Press Wyze Cam Outdoor's SYNC button twice in quick succession, then tap Continue in the app.
- The SYNC button is located on the bottom of the camera.
- Connect to the camera's Wi-Fi network from your phone's Wi-Fi list, then navigate back to the Wyze app. The network will look like this:
- Tap OK when prompted to allow your location, and allow access on the next pop-up.
- Enter a password between 8-16 characters, then tap Save.
- Setting a password is optional, and increases the security of your camera while in Travel Mode.
To Turn Off Travel Mode:
- In the Wyze app, tap Wyze Cam Outdoor, then the
gear icon in the top right. - Tap Exit Travel Mode.
To Enable Travel Mode on Wyze Base Station:
- In the Wyze app, tap Wyze Base Station your cameras are connected to.
- Tap the
gear icon in the top right, then Travel Mode. - Turn on the camera if it isn't already, then tap Continue in the app.
- Press the base station's SYNC button twice in quick succession, then tap Continue in the app.
- The SYNC button is located on the side of Wyze Base Station.
- Connect to Wyze Base Station's Wi-Fi network from your phone's Wi-Fi list, then navigate back to the Wyze app. The network will look like this:
- Setting a password is optional, and increases the security of your base station while in Travel Mode.
In the Wyze app, tap on your Wyze Base Station, then the
Another option: Single-press the SYNC button on Wyze Base Station to exit Travel Mode.
Additional Notes:
- If you lose your Wi-Fi password while in Travel Mode, turn off Travel Mode before resetting your Wi-Fi password. Check out: How do I reset my Travel mode password?
